Drilled the skin and right tie down bracket to 3/8" and installed the eyebolt.
Installed the pitot/static tubes using blue Loctite on the screws. Connected the pitot/static lines to the tubes and secured them with spring clamps.
Checked that all was complete and satisfactory inside the right inboard wing and installed the CCP rivets. The new CCC rivets for the leading edges should arrive in a few days to finish riveting the inboard wings.
Applied Rust-Oleum 209460 "Specialty Plastic Primer" to the rudder cable fairings.
